[PATCH] remove PCI bus initialization from the network drivers
    Joel Sherrill <joel@OARcorp.com>
    joel.sherrill at OARcorp.com
    Mon Aug 22 13:31:29 UTC 2005
Karel Gardas wrote:
> Hello,
> as pointed out but Joel and others, lets remove all the PCI bus
> initialization from all network drivers at once and then see what
> happen. :-)
> Attached patch tested only by compilation on pc386 BSP, also if_fxp
> tested and found working quite well.
That should be enough to make sure it compiles everywhere for this
sort of change.
It is now applied.
Thanks.
--joel
> Cheers,
> Karel
> Karel Gardas                  kgardas at objectsecurity.com
> ObjectSecurity Ltd.           http://www.objectsecurity.com
> Index: c/src/ChangeLog
> RCS file: /usr1/CVS/rtems/c/src/ChangeLog,v
> retrieving revision 1.259
> diff -u -r1.259 ChangeLog
> --- c/src/ChangeLog	15 Aug 2005 13:54:15 -0000	1.259
> +++ c/src/ChangeLog	19 Aug 2005 19:35:08 -0000
> @@ -1,3 +1,8 @@
> +2005-08-18  Karel Gardas  <kgardas at objectsecurity.com>
> +	* libchip/network/if_fxp.c, libchip/network/if_dc.c,
> +	libchip/network/dec21140.c: Remove initialization of PCI bus.
>  2005-08-15	Ralf Corsepius <ralf.corsepius at rtems.org>
>  	* optman/Makefile.am: Add preinstall.am.
> Index: c/src/libchip/network/dec21140.c
> RCS file: /usr1/CVS/rtems/c/src/libchip/network/dec21140.c,v
> retrieving revision 1.30
> diff -u -r1.30 dec21140.c
> --- c/src/libchip/network/dec21140.c	6 May 2005 20:06:17 -0000	1.30
> +++ c/src/libchip/network/dec21140.c	19 Aug 2005 19:35:27 -0000
> @@ -1027,9 +1027,6 @@
>        return 0;
> -   if (pci_initialize() != PCIB_ERR_SUCCESS)
> -      rtems_panic("dec2114x: Unable to initialize PCI");
>      * Find the board
> Index: c/src/libchip/network/if_dc.c
> RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_dc.c,v
> diff -u -r1.2 if_dc.c
> --- c/src/libchip/network/if_dc.c	17 Jun 2005 14:32:23 -0000	1.2
> +++ c/src/libchip/network/if_dc.c	19 Aug 2005 19:35:35 -0000
> @@ -1918,10 +1918,6 @@
>  	 * First, find a DEC board
> -	if (pci_initialize() == PCIB_ERR_NOTPRESENT) {
> -		rtems_panic("PCI BIOS not found !!");
>  	sc = &dc_softc_devs[unitNumber - 1];
>  	ifp = &sc->arpcom.ac_if;
> Index: c/src/libchip/network/if_fxp.c
> RCS file: /usr1/CVS/rtems/c/src/libchip/network/if_fxp.c,v
> retrieving revision 1.16
> diff -u -r1.16 if_fxp.c
> --- c/src/libchip/network/if_fxp.c	18 Jul 2005 15:42:24 -0000	1.16
> +++ c/src/libchip/network/if_fxp.c	19 Aug 2005 19:35:40 -0000
> @@ -447,16 +447,6 @@
>  	s = splimp();
> -	 * init PCI Bios interface...
> -	i = pci_initialize();
> -	DBGLVL_PRINTK(2,"fxp_attach: pcib_init returned %d\n",i);
> -	if (i != PCIB_ERR_SUCCESS) {
> -	  device_printf(dev, "could not initialize pci bios interface\n");
> -	  return 0;
>  	 * find device on pci bus
>      { int j; int pbus, pdev, pfun;
