Building RTEMS. Targets and overrides...
    Ralf Corsepius
    ralf.corsepius at rtems.org
    Thu Aug  4 14:12:34 UTC 2005
On Thu, 2005-08-04 at 13:09 +0200, Per Dalgas Jakobsen wrote:
> Hi all,
> I'm trying to build RTEMS-4.6.2 on a Cygwin host for a Pentium target.
> I have successfully made a cross-toolchain for i586-rtems:
> binutils-2.16.1, newlib (CVS from yesterday) and gcc-3.4.4
Are you sure you did? How did you configure the toolchain?
> Now I got to building RTEMS;
> Unfortunately it seems not so easy to configure RTEMS for an
> 586-optimized toolchain/compiler.
> Any good reasons for that?
Yes, because it doesn't make much sense.
i586 is treated as a cpu variant of the i386 architecture (some call
this the "base architecture"), i.e. as
"i386-rtems-gcc -mtune=pentium"
> I tried a couple of different things to circumvent the problem, but no
> success so far (see below).
> Any suggestions?
> Then I tried
> * configure --prefix=/opt/i586-rtems --target=i386-rtems
> --program-prefix=i586-rtems- --disable-cxx --enable-rtemsbsp=pc586
> --disable-itron
> configure passes, though a couple of suspicious outputs appears from
> c/configure:
> "checking host system type... i386-pc-rtems" - Should host be rtems???
Yes.
> "checking for i386-rtems-strip... no" - Strange... I asked to look for
> i586-rtems-<tool>.
No, you used --target=i386-rtems, i.e. you asked it to look
for i386-rtems-<tool>.
> Checking the call to c/configure:
> /home/Per/Tuxway/src/rtems-4.6.2/c/configure'
> '--prefix=/opt/i586-rtems'
> '--host=i386-rtems' '--build=i686-pc-cygwin' '--target=i386-rtems'
> '--program-prefix=i586-rtems-' '--disable-cxx'
> '--enable-rtemsbsp=pc586'
> '--disable-itron' '--with-target-subdir=i386-rtems'
> '--exec-prefix=/opt/i586-rtems/i386-rtems'  '--cache-file=/dev/null'
> '--srcdir=/home/Per/Tuxway/src/rtems-4.6.2/c'
> "--host" and "--exec-prefix" is specific. - Should it be that way?
Yes.
> And it does not help to try to override "--exec-prefix"...
Right, this is how it is supposed to work. During cross-compilation, GCC
and GNU conventions mandate certain implications, which result into
overriding --exec-prefix.
Ralf
