IRQ latency (was Re: RTEMS-MVME5500 BSP v1.3 available)
Kate Feng
feng1 at bnl.gov
Thu Aug 11 00:36:47 UTC 2005
Kate Feng wrote:
> My impression is that Till Strumann improved the clockIsr()
> routine of c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c
> to optimize the interrupt overhead for all the PowerPCs.
> He filed the PR #773.
> However, in the following thread :
> http://www.rtems.com/ml/rtems-users/2005/march/msg00134.html
> Till Straumann wrote:
> >BTW: I should also have disabled interrupts around the update
> >to avoid the race condition [higher priority IRQ between mfdec
> >and mtdec].
Peter Dufault wrote :
> Me? No, I *never* disable interrupts! (well, almost never).
Yes, it's better to limit it to the minimum.
> But seriously, no I didn't disable interrupts. I'm a firm believer in
>lock-free systems, which to my thinking means trying to push the
>locks down to the hardware level.
I am not sure if you will get an accurate timestamp in you test as
you mention that you use system clock, especially under the heavy
load. Anyway, Till should make a conclusion about its pedigree.
He is the one who made the enhancement in RTEMS4.7 PPC
shared port.
Thanks,
Kate
