IRQ latency (was Re: RTEMS-MVME5500 BSP v1.3 available)
Peter Dufault
dufault at hda.com
Thu Aug 11 01:09:55 UTC 2005
On Aug 10, 2005, at 8:36 PM, Kate Feng wrote:
> Peter Dufault wrote :
>> Me? No, I *never* disable interrupts! (well, almost never).
> Yes, it's better to limit it to the minimum.
>> But seriously, no I didn't disable interrupts. I'm a firm believer in
>> lock-free systems, which to my thinking means trying to push the
>> locks down to the hardware level.
> I am not sure if you will get an accurate timestamp in you test as
> you mention that you use system clock, especially under the heavy
> load. Anyway, Till should make a conclusion about its pedigree.
> He is the one who made the enhancement in RTEMS4.7 PPC
> shared port.
Kate asked me off-list if I'd disabled interrupts in my timings, and
this is how I responded. I'd have been less tongue-in-cheek on-list,
but it's OK with me for anyone forward my emails unless I say not to.
I use the 64-bit Power-PC time counter, not the system clock, so the
timings should be very accurate.
In an earlier posting I said that if something resets that time
counter I'm in trouble, but I'm 99.99% sure that the time counter is
left alone.
Till will tell.
Peter
