Making FAT delete work
    Joel Sherrill <joel@OARcorp.com>
    joel.sherrill at OARcorp.com
    Wed Aug 17 15:52:09 UTC 2005
Eugeny S. Mints wrote:
> Hello Joel!
> Are login/pass into the gnats guest/guest still? I failed to login when
> had tried to take a look at PR744.
Yes.  guest/guest are the read-only account.  RTEMS is the default
database and I just checked that if you don't change the pulldown
for database to RTEMS, you still get there.
--joel
> Thanks,
>     Eugeny
> Joel Sherrill  wrote:
>> Camilo Alejandro Arboleda wrote:
>>> Thanks,
>>> The patch worked fine, it just genarated some warnings about "hunk #x
>>> succeed at line...".
>> And delete works now?
>> Please confirm so I can confidently commit the patch to the trunk and
>> 4.6 branch.
>> --joel
>>> Joel Sherrill <joel at OARcorp.com> escribio':
>>>>> Hi,
>>>>> I'm updating my application from RTEMS 4.5 to RTEMS 4.6.2. After
>>>>> some work I made my flash driver work in the new version. But now I
>>>>> find that 'unlink()' doesn't work anymore.
>>>>> As far as I can see, the problem is in the msdos_eval_path()
>>>>> function. Before deleting the file, RTEMS try to check permissions
>>>>> for ".." directory, but msdos_eval_path fails with 'ENOTDIR'. I
>>>>> want to copy the IMFS functionality, but I'm not able to figure how
>>>>> to open the parent node of a file on msdosfs.
>>>>> Maybe I'm missing something. Is there someone who is using FAT
>>>>> support and is able to delete files?
>>>> Is this PR744?  If so, there is an attached patch.  It was made versus
>>>> CVS but I don't see it applied to the CVS head.
>>>> If you can make it work and submit it as a patch against 4.6 and the
>>>> CVS
>>>> head, it would be greatly appreciated.  This needs to be fixed.
>>>> I don't know what the issue was regarding this patch.  It is not
>>>> uncommon for me to wait until there is a patch against 4.6 and CVS head
>>>> if the issue applies to both.
>>>>> Thanks in advance,
