Making FAT delete work
    Eugeny S. Mints
    emints at ru.mvista.com
    Wed Aug 17 13:29:03 UTC 2005
Hello Joel!
Are login/pass into the gnats guest/guest still? I failed to login when
had tried to take a look at PR744.
Thanks,
	Eugeny
Joel Sherrill  wrote:
> Camilo Alejandro Arboleda wrote:
>> Thanks,
>> The patch worked fine, it just genarated some warnings about "hunk #x
>> succeed at line...".
> And delete works now?
> Please confirm so I can confidently commit the patch to the trunk and
> 4.6 branch.
> --joel
>> Joel Sherrill <joel at OARcorp.com> escribio':
>>>> Hi,
>>>> I'm updating my application from RTEMS 4.5 to RTEMS 4.6.2. After
>>>> some work I made my flash driver work in the new version. But now I
>>>> find that 'unlink()' doesn't work anymore.
>>>> As far as I can see, the problem is in the msdos_eval_path()
>>>> function. Before deleting the file, RTEMS try to check permissions
>>>> for ".." directory, but msdos_eval_path fails with 'ENOTDIR'. I want
>>>> to copy the IMFS functionality, but I'm not able to figure how to
>>>> open the parent node of a file on msdosfs.
>>>> Maybe I'm missing something. Is there someone who is using FAT
>>>> support and is able to delete files?
>>> Is this PR744?  If so, there is an attached patch.  It was made versus
>>> CVS but I don't see it applied to the CVS head.
>>> If you can make it work and submit it as a patch against 4.6 and the CVS
>>> head, it would be greatly appreciated.  This needs to be fixed.
>>> I don't know what the issue was regarding this patch.  It is not
>>> uncommon for me to wait until there is a patch against 4.6 and CVS head
>>> if the issue applies to both.
>>>> Thanks in advance,
