Almost done
    Camilo Alejandro Arboleda
    camilo.arboleda at spymac.com
    Wed Aug 17 22:41:06 UTC 2005
Does the standard gdb version work? Is there any patch for rtems?
Chris Johns escribió:
> Camilo Alejandro Arboleda wrote:
>> My migration to RTEMS 4.6 is almost ready. Now I have a problem with
>> GDB. When I use gdb 5.2, I cannot inspect any variable. It says that
>> it cannot convert floating point to non floating point.
>> My application is written in C++, and I'm not sure if the changes in
>> C++ ABI in gcc could cause this. Is anybody using C++ as main
>> language with RTEMS 4.6?
> Yes on the Coldfire and i386 (PC) and it works ok. This is gdb 6.0.
> The later gdb versions do have better C++ support. I seem to remember
> namespace support was a problem and gdb could get confused.
