Almost done
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Wed Aug 17 23:08:15 UTC 2005
Camilo Alejandro Arboleda wrote:
> Does the standard gdb version work? Is there any patch for rtems?
If you are not using somethink like BDM, you should be able to
get by with the corresponding no OS target like m68k-elf or
powerpc-elf. Most targets are now elf.
--joel
>>> My migration to RTEMS 4.6 is almost ready. Now I have a problem with
>>> GDB. When I use gdb 5.2, I cannot inspect any variable. It says that
>>> it cannot convert floating point to non floating point.
>>> My application is written in C++, and I'm not sure if the changes in
>>> C++ ABI in gcc could cause this. Is anybody using C++ as main
>>> language with RTEMS 4.6?
>> Yes on the Coldfire and i386 (PC) and it works ok. This is gdb 6.0.
>> The later gdb versions do have better C++ support. I seem to remember
>> namespace support was a problem and gdb could get confused.
