Almost done
    Chris Johns
    chrisj at rtems.org
    Wed Aug 17 23:30:00 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote:
> If you are not using somethink like BDM, you should be able to
> get by with the corresponding no OS target like m68k-elf or
> powerpc-elf. Most targets are now elf.
Correct. This is gdb built on RedHat FC4 for the i386:
$ i386-elf-gdb --version
GNU gdb 6.0
Copyright 2003 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain
conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.  Type "show warranty" for details.
This GDB was configured as "--host=i386-pc-linux-gnu --target=i386-elf".
On the i386 I use a network boot then debug via the serial port.
  Chris Johns
