Freescale MPC8247 and/or MPC5200 port ?
    Ed Sutter
    esutter at lucent.com
    Thu Aug 18 14:13:59 UTC 2005
Victor,
Not sure of the similarity, but the micromonitor tarball has
a port to a MPC852t based board with FEC, ethernet and serial port
drivers (polled).  That may give you a start anyway.  I've hooked
RTEMS to micromonitor in the past, and it works out pretty well.
If useful, go to http://www.microcross.com/html/micromonitor.html
for a download point.
Ed
> Joel Sherrill <joel at OARcorp.com> wrote:
>> Victor V. Vengerov wrote:
>>> Markku,
>>> We are planning BSP development for MPC5200 (5200Lite evaluation
>>> board) and have made some preliminary analysis for this work.
>>> It looks like MPC5200 architecture is quite new, so most drivers
>>> (serial, network, IDE, PCI, ...) and initialization code need to be
>>> developed from scratch. From other side, 603e core is already
>>> supported. We have not found BSP which is really similar to MPC5200
>>> one. So my advice is to start from scratch looking to other powerpc
>>> BSPs (score603e?) for reference.
>> If it is a 603e core with a handful of on-CPU peripherals, talk to
>> someone at FreeScale and try to get them to tell you if the on-CPU
>> peripherals are the same as or similar to those on any other part.
>> Many times they do not really advertise it but they are the same
>> or slightly modified.  They really could be new but you might get
>> lucky.
> Yes, I know it. Actually I have compared their on-chip peripheral (at
> least, FEC, ATA, DMA, PSC - Programmable Serial Controller) against at
> least all m68k/coldfire and Motorola PowerPC chips supported in RTEMS.
> Nothing similar. Also, we have looked into Linux kernel - MPC5200
> peripheral drivers are separate from other ex-Motorola chips.
>> The ep1a or mpc8260 may also be good BSPs to look at.  It largely
>> depends on what the on-CPU peripherals look most like.
> No, they are different - at least mpc8260, which is known to me and I'm
> sure I have checked it.
> Thanks,
> Victor
