test sp16 failed
    Joel Sherrill <joel@OARcorp.com>
    joel.sherrill at OARcorp.com
    Mon Aug 22 22:40:26 UTC 2005
Philippe Simons wrote:
> I'm having some issue with region manager and my bsp, but dont have a
> clue on why
> here is the output of sp16.exe
> *** TEST 16 ***
> TA1 - rtems_region_ident - rnid => 32010002
> TA1 - rtems_region_get_segment - wait on 100 byte segment from region 2
> TA1 - got segment from region 2 - 0x00000040
> TA1 - rtems_region_get_segment - wait on 3K segment from region 3
> TA1 - got segment from region 3 - 0x00000080
> TA1 - rtems_region_get_segment - get 3080 byte segment from region 1 -
> NO_WAIT
> TA1 - got segment from region 1 - 0x00000060
> TA1 - rtems_task_wake_after - yield processor
> TA2 - rtems_region_get_segment - wait on 2K segment from region 1
> TA3 - rtems_region_get_segment - wait on 3968 byte segment from region 2
> rtems_region_get_segment FAILED -- expected (successful completion) got
> (specified size was invalid)
> bsp_reset.....
Can you step into the get_segment function and see why it was rejected?
In the mean time, I will verify the test is OK on another BSP.
> the gp32 bsp is based on csb336 bsp
> TIA
> Philippe
