Developent Environments for RTEMS
    Jiri Gaisler
    jiri at gaisler.com
    Fri Aug 26 19:10:18 UTC 2005
Our eclipse plugin is for free, it is only the ERC32 simulator
which costs money. We are in fact about to release a new
version of the plugin, compatible with the latest version
of eclipse and cdt. What you need is a gdb-stub that runs
on the target, like the rdbmon stub we provided with LECCS
(also free). If you have ethernet on your board, it would
probably be better to port the ethernet gdb server to the
sparc port.
Note also that we provide our plugin in full source
code (GPL), so you can modify it and tune at will.
Jiri Gaisler.
PS. My development environment is xvile + a couple of
     xterm/bash windows. Works equally well for both
     VHDL anc C. For serious problems, I also use grep .. :-)
Fabrício de Novaes Kucinskis wrote:
> Hi all,
> I'm using RTEMS with an ERC32 board. I'm creating programs using a regular
> text editor, and compiling by command line. Now I'm looking for something
> better, to improve our productivity.
> I know that Gaisler Research have an Eclipse plugin to develop to
> ERC32/Leon, but I can't pay for this at the moment. I would like to know
> other options. What do you use to develop to RTEMS?
> Can I configure Eclipse to compile to RTEMS? Do you know / use different
> IDEs?
> Thanks in advance,
> Fabrício de Novaes Kucinskis - DEA / INPE
> Divisão de Eletrônica Aeroespacial
> Instituto Nacional de Pesquisas Espaciais
