RTEMS with ARM LPC2138
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Dec 15 13:18:51 UTC 2005
Jay Monkman wrote:
> Sam wrote:
>>Jay Monkman wrote:
>>>Sam wrote:
>>>>Hi, what difference between this with WRAP? Wrap is only around 120USD.
>>>What's WRAP?
>>Here is its reference:
>>http://www.pcengines.ch/
> The obvious difference is that WRAP uses an x86 and the Cogent board uses a MIPS
> CPU.
The Ethernet is 1-3 Ethernet channels using a National DP83816.  Is this
a supported NIC?
If someone has used that NIC, then this doesn't seem to be a bad board
for RTEMS.  It is certainly cheap.
