RTEMS 4.6.5 biuld failed in FreeBSD 6.0
Siddons, David siddons at bnl.gov
Sun Dec 25 16:28:46 UTC 2005
Eric Norum has written a nice step-by-step tutorial for getting RTEMS up and running. It is aimed at getting a particular application working, but most of it is just what you are looking for. It is at:
http://www.aps.anl.gov/epics/base/RTEMS/tutorial/
Pete.
-----Original Message-----
Sent:	Sat 12/24/2005 8:29 PM
To:
Cc:	rtems-users at rtems.com
Subject:	Re: RTEMS 4.6.5 biuld failed in FreeBSD 6.0
e.stiebler wrote:
> Sam wrote:
>> Hi, I have checked out 4.7, how to compile the source? I don't find a
>> "configure" file in the rtems/ directory.
> There should be bootstrap or something alike ...
Yes, there is a bootstrap program, but it complains alot of GNU files
are missing from my FreeBSD system:
aclocal: not found
automake: not found
autoconf: not found
grep: Makefile.in: No such file or directory
I also tried to look for a howto, guideline or installation notes , but
I couldn't find a suitable notes that easy to read from Unix...
thanks
Sam
