ppc multlibs and BSP removal was Re: powerpc altivec support
Ralf Corsepius ralf.corsepius at rtems.org
Thu Feb 10 12:38:51 UTC 2005
On Thu, 2005-02-10 at 15:07 +0300, Sergei Organov wrote:
> Ralf Corsepius <ralf.corsepius at rtems.org> writes:
> > On Wed, 2005-02-09 at 19:40 -0800, Till Straumann wrote:
> > PPC_HAS_DOUBLE is primarily used in task-switches, so I am wondering
> > what PPC_HAS_DOUBLE actually means:
> > * The CPU lack some (double) instructions, therefore requires a
> > customized task-switch. Makes me wonder, what happens with GCC generated
> > FPU code on these CPUs.
> > * The CPU needs customization because it lacks a feature.
> It means that CPU lacks both double registers and double instructions, I
> think. I.e., FPU registers are 32 bits and single-precision instructions
> should be used for load/store.
> The only such CPU in RTEMS seems to be 602,
As far as PPC_HAS_DOUBLE is concerned, yes.
As far as PPC_HAS_FPU is concerned, the situation is not clear to me.
>  but I've no idea if it's in
> fact used/supported.
For GCC the 602, 603 and 603e are identical.
They apply the same ISA:
from rs6000.c:
{"602", PROCESSOR_PPC603, POWERPC_BASE_MASK | MASK_PPC_GFXOPT},
{"603", PROCESSOR_PPC603, POWERPC_BASE_MASK | MASK_PPC_GFXOPT},
{"603e", PROCESSOR_PPC603, POWERPC_BASE_MASK | MASK_PPC_GFXOPT},
from rs6000.h:
%{mcpu=602: -mppc} \
%{mcpu=603: -mppc} \
%{mcpu=603e: -mppc} \
So the only part being involved which distingushes between them is
RTEMS.
i.e. if all 602/603/603e specific defines could be removed from cpukit,
we could fold all of them into one multilib variant.
ATM, there remains PPC_HAS_DOUBLE (used by the 602) and
PPC_LOW_POWER_MODE (used by the 603e) which prevent this.
All other defines currently being used by the 602/603/603e can be
eliminated (e.g. *_CACHE), or generalized (PPC_ALIGNMENT =
PPC_STACK_BOUNDARY (8 for EABI, 16 for SYSV))
Ralf
