ppc multlibs and BSP removal was Re: powerpc altivec support
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Thu Feb 10 14:47:51 UTC 2005
Ralf Corsepius wrote:
> On Thu, 2005-02-10 at 15:07 +0300, Sergei Organov wrote:
>>Ralf Corsepius <ralf.corsepius at rtems.org> writes:
>>>On Wed, 2005-02-09 at 19:40 -0800, Till Straumann wrote:
>>>PPC_HAS_DOUBLE is primarily used in task-switches, so I am wondering
>>>what PPC_HAS_DOUBLE actually means:
>>>* The CPU lack some (double) instructions, therefore requires a
>>>customized task-switch. Makes me wonder, what happens with GCC generated
>>>FPU code on these CPUs.
>>>* The CPU needs customization because it lacks a feature.
>>It means that CPU lacks both double registers and double instructions, I
>>think. I.e., FPU registers are 32 bits and single-precision instructions
>>should be used for load/store.
>>The only such CPU in RTEMS seems to be 602,
> As far as PPC_HAS_DOUBLE is concerned, yes.
> As far as PPC_HAS_FPU is concerned, the situation is not clear to me.
>> but I've no idea if it's in
>>fact used/supported.
> For GCC the 602, 603 and 603e are identical.
> They apply the same ISA:
> from rs6000.c:
> {"602", PROCESSOR_PPC603, POWERPC_BASE_MASK | MASK_PPC_GFXOPT},
> {"603", PROCESSOR_PPC603, POWERPC_BASE_MASK | MASK_PPC_GFXOPT},
> {"603e", PROCESSOR_PPC603, POWERPC_BASE_MASK | MASK_PPC_GFXOPT},
> from rs6000.h:
> %{mcpu=602: -mppc} \
> %{mcpu=603: -mppc} \
> %{mcpu=603e: -mppc} \
> So the only part being involved which distingushes between them is
> RTEMS.
> i.e. if all 602/603/603e specific defines could be removed from cpukit,
> we could fold all of them into one multilib variant.
Let's head for that.  If someone comes up with a real 602 and wants a
BSP for it, we can encourage them to do the double emulation.
> ATM, there remains PPC_HAS_DOUBLE (used by the 602) and
> PPC_LOW_POWER_MODE (used by the 603e) which prevent this.
Double check me but PPC_LOW_POWER_MODE is defined but never used.
I would assert that it SHOULD be in libcpu/powerpc somewhere.
Offhand, I don't know how it works.  Normally, low power requires
some CPU model specific idle thread.  It looks like the 603e has it is
CPU specific HID registers so I would say this logic belows in
libcpu/powerpc/shared in a lowpower/idle file.  It might be nothing more
than letting that file define the IDLE thread based on the CPU model.
The reality is that right now, I can find no code using this information.
> All other defines currently being used by the 602/603/603e can be
> eliminated (e.g. *_CACHE), or generalized (PPC_ALIGNMENT =
> PPC_STACK_BOUNDARY (8 for EABI, 16 for SYSV))
That certainly simplifies it. :)
--joel
