a problem with serial port (can't post in mail-list)
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Feb 14 12:16:51 UTC 2005
I received this personally and am forwarding it to the list.
I sent David info on why he might not have been able to post.
--joel
David García wrote:
> Hi, I've tried to post my doubt in the rtems-users at rtems.com
> <mailto:rtems-users at rtems.com> mailing list but I'm not really sure if
> it has been send correctly as there was no feedback and my post doesn't
> appear in the website.
> Is for that I'm writting to you directly becaus I'm having some problems
> with rtems, and I explain it below:
> We are trying to do a migration from a Linux application to RTEMS v4.6
> using the pc386 BSP. The application runs well under Linux but under
> RTEMS does not run well.
> The cross compiler does not report an error but at runtime the code hangs.
> We think the code hangs when we do the following call to ioctl:
> "ioctl(fdes, FIONREAD, (int)&unread)"
> - fdes is the file descriptor that we have obtained by opening the
> serial port COM1, which is registered in the system with the name
> "/dev/ttyS1". Since the function open "/dev/ttyS1",O_RDWR | O_NONBLOCK |
> O_NOCTTY) does not result in an error we assume that the drivers have
> been initialized correctly. We used the TT1_DRIVER_TABLE_ENTRY, defined
> in the file tty_drv.h, to add the appropriate entry to the device driver
> table of the RTEMS configuration.
> - (int)&unread is the pointer to an integer were we want to obtain the
> unread bytes.
> We have seen that FIONREAD definition in ioccom.h differs from the one
> that is defined in the ioctls.h header of linux libraries.
> We suspect that is when we call the function ioctl that the application
> fails, and the systems hangs up.
> The question is: should we do the ioctl call differently? Or could the
> problem be in a different point of the application?
> Any sugestion will be wellcome.
> If you would like more information please do not hesitate to email back.
> Thank you very much for your patience.
> Best regards
> David García Antón
> headhunternx at hotmail.com
