Passing Parameter(s) to tasks/threads
Smith, Gene gene.smith at siemens.com
Mon Feb 14 21:43:25 UTC 2005
Aaron J. Grier wrote, On 2/11/2005 2:41 PM:
> On Thu, Feb 10, 2005 at 07:42:42PM -0500, Smith, Gene wrote:
>>I need to pass from 0 to 10 integer parameters to my tasks when they
>>are started with rtems_task_start().
> if sizeof(rtems_task_argument) == sizeof(int**) on your target, you can
> use explicit casts to convert between the two.
Yes, this does work for me. Possily a kluge but it works!
> another way to do would be to pass a message queue ID as an argument,
> and then have the task read its parameters from that queue.
I might look into this way. Thanks!
