RTEMS Version 4.5 TCP/IP connection blocks
Wilfried Busalski w.busalski at lancier-monitoring.de
Thu Feb 17 10:38:05 UTC 2005
Hi cummunity
I've have a big problem.
For an application I need a TCP/IP Connection that reading will not block.
I use the funkcion:
fcntl (fd, F_SETFL, O_NONBLOCK);
An the result is, that the reading is blocked every time.
In Version RTEMS 4.6.2 the source works correct.
What can do to fix this problem???
Regards
Wilfried Busalski
