New user - timer problems
Richardson, Anthony ar63 at evansville.edu
Mon Feb 21 14:57:00 UTC 2005
I think I am missing something fundamental with regard to
the use of timers.  Calls to rtems_timer_create() and
rtems_timer_initiate_server() return a status of
RTEMS_NOT_CONFIGURED.  If I ignore the error returns
everything seems to work ok, but I'm concerned I'm not
configuring something that I should be.
A complete, simple test case is included below.  The
#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
lines don't seem to help.  I threw them in when
trying to get rid of the error.
I'm using RTEMS 4.6.2 on the PC.
Thanks,
Tony Richardson
#include <bsp.h>
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS      3
#define CONFIGURE_MAXIMUM_TIMERS     1
#define CONFIGURE_MAXIMUM_SEMAPHORES 1
#define CONFIGURE_INIT
rtems_task Init(rtems_task_argument arg);
#include <confdefs.h>
rtems_id sem_id;
rtems_id tim_id;
rtems_timer_service_routine my_timer(rtems_id timer, void *arg)
   // We just need to release the semaphore
   rtems_semaphore_release(sem_id);
rtems_task Init(rtems_task_argument ignored)
  rtems_status_code status;
  // Create semaphore, initially it should be unavailable
  rtems_semaphore_create(
     rtems_build_name('S','M','0','1'),
     0,
     RTEMS_SIMPLE_BINARY_SEMAPHORE,
     0,
     &sem_id);
  status = rtems_timer_create(
     rtems_build_name('T','M','0','1'),
     &tim_id);
  // timer_create seems to always return an RTEMS_NOT_CONFIGURED error
  // but works never-the-less.
  printf("status = %d\n", status);
  if (status != RTEMS_SUCCESSFUL && status != RTEMS_NOT_CONFIGURED) {
     printf("Error creating timer 1\n");
     exit(0);
     RTEMS_TIMER_SERVER_DEFAULT_PRIORITY,
     RTEMS_MINIMUM_STACK_SIZE,
     RTEMS_DEFAULT_ATTRIBUTES);
     exit(0);
  printf("Entering application loop ...\n");
  while(1) {
     printf("Hello world!\n");
     // fire timer
     rtems_timer_server_fire_after(
        tim_id,
        5000/rtems_configuration_get_milliseconds_per_tick(),
        my_timer,
        (void *)NULL);
     // wait for the semaphore, it is released by the timer
     rtems_semaphore_obtain(sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
  exit( 0 );
