New user - timer problems
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Feb 22 15:48:38 UTC 2005
Richardson, Anthony wrote:
> I think I am missing something fundamental with regard to
> the use of timers. Calls to rtems_timer_create() and
> rtems_timer_initiate_server() return a status of
> RTEMS_NOT_CONFIGURED. If I ignore the error returns
> everything seems to work ok, but I'm concerned I'm not
> configuring something that I should be.
You are probably using hello world as a starting point.
Look in the Makefile for
# optional managers required
MANAGERS=io
and change io to "all"
> A complete, simple test case is included below. The
> #define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> lines don't seem to help. I threw them in when
> trying to get rid of the error.
> I'm using RTEMS 4.6.2 on the PC.
> Thanks,
> Tony Richardson
> #include <bsp.h>
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_TASKS 3
> #define CONFIGURE_MAXIMUM_TIMERS 1
> #define CONFIGURE_MAXIMUM_SEMAPHORES 1
> #define CONFIGURE_INIT
> rtems_task Init(rtems_task_argument arg);
> #include <confdefs.h>
> #include <stdio.h>
> #include <string.h>
> #include <stdlib.h>
> rtems_id sem_id;
> rtems_id tim_id;
> rtems_timer_service_routine my_timer(rtems_id timer, void *arg)
> // We just need to release the semaphore
> rtems_semaphore_release(sem_id);
> rtems_task Init(rtems_task_argument ignored)
> rtems_status_code status;
> // Create semaphore, initially it should be unavailable
> rtems_semaphore_create(
> rtems_build_name('S','M','0','1'),
> 0,
> RTEMS_SIMPLE_BINARY_SEMAPHORE,
> 0,
> &sem_id);
> status = rtems_timer_create(
> rtems_build_name('T','M','0','1'),
> &tim_id);
> // timer_create seems to always return an RTEMS_NOT_CONFIGURED error
> // but works never-the-less.
> printf("status = %d\n", status);
> if (status != RTEMS_SUCCESSFUL && status != RTEMS_NOT_CONFIGURED) {
> printf("Error creating timer 1\n");
> exit(0);
> RTEMS_TIMER_SERVER_DEFAULT_PRIORITY,
> RTEMS_MINIMUM_STACK_SIZE,
> RTEMS_DEFAULT_ATTRIBUTES);
> exit(0);
> printf("Entering application loop ...\n");
> while(1) {
> printf("Hello world!\n");
> // fire timer
> rtems_timer_server_fire_after(
> tim_id,
> 5000/rtems_configuration_get_milliseconds_per_tick(),
> my_timer,
> (void *)NULL);
> // wait for the semaphore, it is released by the timer
> rtems_semaphore_obtain(sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> exit( 0 );
joel at OARcorp.com On-Line Applications Research
