powerpc-rtems-4.7-gcc-4.0 patch commited
Till Straumann strauman at slac.stanford.edu
Thu Feb 17 18:31:42 UTC 2005
Ralf Corsepius wrote:
>On Thu, 2005-02-17 at 08:27 -0800, Till Straumann wrote:
>>Hi Ralf
>>>Hi,
>>>FYI: I have committed my powerpc RTEMS-gcc multilib patches to GCC's CVS
>>>trunk (aka. GCC-4.0).
>>>This patch introduces a completely new layout of powerpc multilibs:
>>># powerpc-rtems4.7-gcc --print-multi-lib
>>>.;@mrelocatable-lib at mno-eabi@mstrict-align
>>>m403;@mcpu=403 at mrelocatable-lib@mno-eabi at mstrict-align
>>>m505;@mcpu=505 at mrelocatable-lib@mno-eabi at mstrict-align
>>>m601;@mcpu=601 at mrelocatable-lib@mno-eabi at mstrict-align
>>>m603e;@mcpu=603e at mrelocatable-lib@mno-eabi at mstrict-align
>>>m604;@mcpu=604 at mrelocatable-lib@mno-eabi at mstrict-align
>>Why do we need a m604 (and possibly more CPU variants)?
>There is a BSP in CVS which uses the m604.
??? I guess I said this before, but code generated for mcpu=powerpc
executes on
*any* integer PPC cpu. If the BSP checks for #ifdef mpc604 [I cant'
think of a reason
since the code in 'shared' does run-time detection of the relevant
features] it would
be enough to add -mcpu=604 to the BSP's CFLAGS.
Sorry, but I think there's still way too much bloat...
>> I thought
>>the #ifdefs testing for a CPU type in RTEMS have been cleaned up?
>They have been massively cleaned up, but there still remains a lot of
>arkwardness :(
I can believe that :-(
>>>m860;@mcpu=860 at mrelocatable-lib@mno-eabi at mstrict-align
>>>m7400;@mcpu=7400 at mrelocatable-lib@mno-eabi at mstrict-align
>>I don't see the altivec options here - I guess --print-multi-lib doesn't
>>show all the active options?
>-mcpu=7400 implies -maltivec
does it also imply mabi=altivec? Note that this is crucial since it
enforces the correct
stack alignment. For altivec to work properly, ALL code must be
generated -mabi=altivec
otherwise, the altivec register save area on the stack is not properly
aligned.
>-mcpu=7450 is "multlib"-matched to -mcpu=7400, i.e. uses the same
>multilibs as -mcpu=7400
good.
>>>nof;@msoft-float at mrelocatable-lib@mno-eabi at mstrict-align
>>>m601/nof;@mcpu=601 at msoft-float@mrelocatable-lib at mno-eabi@mstrict-align
>>>m603e/mpc8260;@mcpu=603e at Dmpc8260@mrelocatable-lib at mno-eabi@mstrict-align
>>>m603e/nof;@mcpu=603e at msoft-float@mrelocatable-lib at mno-eabi@mstrict-align
>>>m603e/mpc8260/nof;@mcpu=603e at Dmpc8260@msoft-float at mrelocatable-lib@mno-eabi at mstrict-align
>>>m604/nof;@mcpu=604 at msoft-float@mrelocatable-lib at mno-eabi@mstrict-align
>>>m7400/nof;@mcpu=7400 at msoft-float@mrelocatable-lib at mno-eabi@mstrict-align
>>I definitively don't see the point of having a 604 and 7400 soft float
>>variant.
>Convenience - You don't want to/don't need a necessity to test your BSPs
>with FPU disabled? I think this is necessary and convenient when
>developing BSPs.
The other way round - I found problematic areas in newlib by using the
'hard-float' variant
in combination with a disabled FPU. This way, I find buggy tasks that
claim to be 'integer-only'.
I can't think of a situation where soft-float would be useful.
Don't get me wrong - I'm not barfing, I just try to keep variants to a
minimum which
at the end of the day should make your life easier...
T.
>Ralf
