Unified PCI API
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Sun Feb 20 12:28:46 UTC 2005
Chris Caudle wrote:
> On Saturday 19 February 2005 06:49 pm, Joel Sherrill <joel at OARcorp.com> wrote:
>>For those who care, the x86 PCI API uses a "signature u32" to identify
>>devices while the PowerPC/cpukit API uses a "bus, device" combination to
>>identify devices.
> Assuming the u32 is because of Intel PCI BIOS convention, it is actually a
> multi-field number that is the concatenation of bus, device, function.
> My opinion is that bus, device, function is more clear because it maps
> directly to how the bus access is defined.
> It sounds like the PowerPC API made an expediency in only using bus, device
> but for completeness the API should use bus, device, function so that
> multi-function devices can be handled correctly.
I'm sorry. It does include function. For example:
int
pci_read_config_byte(
unsigned char bus,
unsigned char slot,
unsigned char function,
unsigned char where,
unsigned char * val)
I suppose the next step after making it one API is to switch to C99
types like uint8_t.
joel at OARcorp.com On-Line Applications Research
