New user - timer problems
Richardson, Anthony
ar63 at evansville.edu
Tue Feb 22 17:59:53 UTC 2005
Duh. Thanks that was it.
Tony
> -----Original Message-----
> From: Joel Sherrill <joel at OARcorp.com>
> [mailto:joel.sherrill at OARcorp.com]
> Sent: Tuesday, February 22, 2005 9:49 AM
> To: Richardson, Anthony
> Cc: rtems-users at rtems.com
> Subject: Re: New user - timer problems
> Richardson, Anthony wrote:
> > I think I am missing something fundamental with regard to
> > the use of timers. Calls to rtems_timer_create() and
> > rtems_timer_initiate_server() return a status of
> > RTEMS_NOT_CONFIGURED. If I ignore the error returns
> > everything seems to work ok, but I'm concerned I'm not
> > configuring something that I should be.
> You are probably using hello world as a starting point.
> Look in the Makefile for
> # optional managers required
> MANAGERS=io
> and change io to "all"
> > A complete, simple test case is included below. The
> > #define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
> > #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
> > lines don't seem to help. I threw them in when
> > trying to get rid of the error.
> > I'm using RTEMS 4.6.2 on the PC.
> > Thanks,
> > Tony Richardson
> > #include <bsp.h>
> > #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > #define CONFIGURE_MAXIMUM_TASKS 3
> > #define CONFIGURE_MAXIMUM_TIMERS 1
> > #define CONFIGURE_MAXIMUM_SEMAPHORES 1
> > #define CONFIGURE_INIT
> > rtems_task Init(rtems_task_argument arg);
> > #include <confdefs.h>
> > #include <stdio.h>
> > #include <string.h>
> > #include <stdlib.h>
> > rtems_id sem_id;
> > rtems_id tim_id;
> > rtems_timer_service_routine my_timer(rtems_id timer, void *arg)
> > // We just need to release the semaphore
> > rtems_semaphore_release(sem_id);
> > rtems_task Init(rtems_task_argument ignored)
> > rtems_status_code status;
> > // Create semaphore, initially it should be unavailable
> > rtems_semaphore_create(
> > rtems_build_name('S','M','0','1'),
> > 0,
> > RTEMS_SIMPLE_BINARY_SEMAPHORE,
> > 0,
> > &sem_id);
> > status = rtems_timer_create(
> > rtems_build_name('T','M','0','1'),
> > &tim_id);
> > // timer_create seems to always return an
> RTEMS_NOT_CONFIGURED error
> > // but works never-the-less.
> > printf("status = %d\n", status);
> > if (status != RTEMS_SUCCESSFUL && status !=
> RTEMS_NOT_CONFIGURED) {
> > printf("Error creating timer 1\n");
> > exit(0);
> > RTEMS_TIMER_SERVER_DEFAULT_PRIORITY,
> > RTEMS_MINIMUM_STACK_SIZE,
> > RTEMS_DEFAULT_ATTRIBUTES);
> > exit(0);
> > printf("Entering application loop ...\n");
> > while(1) {
> > printf("Hello world!\n");
> > // fire timer
> > rtems_timer_server_fire_after(
> > tim_id,
> > 5000/rtems_configuration_get_milliseconds_per_tick(),
> > my_timer,
> > (void *)NULL);
> > // wait for the semaphore, it is released by the timer
> > rtems_semaphore_obtain(sem_id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
> > exit( 0 );
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
