qemu configuration [was: netdemo echoServer issue [was: Re: listen/select and then accept pattern not working?]]
    Keith Robertson
    kjrobert at alumni.uwaterloo.ca
    Mon Jan 17 20:02:14 UTC 2005
Karel Gardas wrote:
> BTW: I haven't know that RTEMS provides also DHCP client, so I always
> configured networking manually. Thanks for this information!
Yes, I agree, the qemu dhcp server is very handy.
>>4) Run the following commands to create a grub boot iso
>>$cd ~
>>$mkdir -p iso/boot/grub
>>$cp /usr/share/grub/stage2_eltorito iso/boot/grub
> I've not been able to find out where is stage2_eltorito located,
> especially when it does not build with my grub (0.93) sources...
Are you using Fedora by any chance?  I noticed that they seemed not to
include the aforementioned file (maybe they renamed or moved it??).  In
any case, I just copied stage2_eltorito across from my debian machine.
It definitely comes with the main sources from
http://www.gnu.org/software/grub/ though.
See also:
http://www.gnu.org/software/grub/manual/html_node/Making-a-GRUB-bootable-CD-ROM.html
which mentions where to find the file in the default distribution.
Cheers,
Keith
