PCI lookup issue: 3c905C-TX not found by RTEMS.
Karel Gardas kgardas at objectsecurity.com
Tue Jan 18 21:51:43 UTC 2005
On Tue, 18 Jan 2005 gregory.menke at gsfc.nasa.gov wrote:
>  > By your `I think the next thing to do in this case is to instrument the
>  > function with printk's and see how the nested loops work.' -- do you mean
>  > BusCountPCI function?
> Yes- but your results above suggest 1 is the return value anyhow- so
> no need for further work that way.
> As a test, try hardcoding the BusCountPCI() to return 2, that way the
> device scan routine will at least try other busses.
Unfortunatelly it is not found on second bus too... Should I go ahead and
test 3th bus?
Thanks,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
