PCI lookup issue: 3c905C-TX not found by RTEMS.
Karel Gardas kgardas at objectsecurity.com
Mon Jan 24 21:54:12 UTC 2005
On Mon, 24 Jan 2005, Karel Gardas wrote:
> Well, then the only other issue is that RTEMS after printing:
> etherlink: device '3Com 3c905C-TX Fast Etherlink XL', name 'elnk1', pci
> 00:08.00, 16 rx.16 tx buffers
> freeze.
It seems it freeze on call:
   printk("rtems_timer_create...");
   if( rtems_timer_create( rtems_build_name( 'X', 'L', 't',
(char)(sc->xl_unit & 255)),
                           &sc->stat_timer_id ) != RTEMS_SUCCESSFUL )
      printk("etherlink : unit elnk%d unable to create stats timer\n",
sc->xl_unit );
      return 0;
   printk("OK\n");
I see only `rtems_timer_create...' on the console.
Any idea what might be the issue with creating a timer for NIC?
Thanks,
Karel
ObjectSecurity Ltd.           http://www.objectsecurity.com
