PCI lookup issue: 3c905C-TX not found by RTEMS.
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Mon Jan 24 22:14:14 UTC 2005
Karel Gardas writes:
 > On Mon, 24 Jan 2005, Karel Gardas wrote:
 > > Well, then the only other issue is that RTEMS after printing:
 > > etherlink: device '3Com 3c905C-TX Fast Etherlink XL', name 'elnk1', pci
 > > 00:08.00, 16 rx.16 tx buffers
 > > freeze.
 > It seems it freeze on call:
 >    printk("rtems_timer_create...");
 >    if( rtems_timer_create( rtems_build_name( 'X', 'L', 't',
 > (char)(sc->xl_unit & 255)),
 >                            &sc->stat_timer_id ) != RTEMS_SUCCESSFUL )
 >       printk("etherlink : unit elnk%d unable to create stats timer\n",
 > sc->xl_unit );
 >       return 0;
 >    printk("OK\n");
 > I see only `rtems_timer_create...' on the console.
 > Any idea what might be the issue with creating a timer for NIC?
Timers aren't particularly associated with nic's.  What have you
defined CONFIGURE_MAXIMUM_TIMERS to in your project?
Gregm
