rpm error
    Mark Vander Voord
    mvandervoord at gmail.com
    Mon Jan  3 19:26:49 UTC 2005
Ed:
I'm not an RPM expert, so this may not be correct.  I believe,
however, that the error that you are getting means that the packages
you are trying to install are built for i686, but the packages that
they depend on that are on your system are not.  RH9 is compiled for
i386, I believe.
I believe this means that you need to recompile the rpm's for yourself
targeting i386.
Anyone more familiar with RPM's agree with this?
On Mon, 03 Jan 2005 13:39:28 -0500, Ed Sutter <esutter at lucent.com> wrote:
> Probably a dumb question...
> I'm trying for the first time to install the RTEMS tool binaries
> onto a Linux Box running RH9.  I get the following message...
> "package .... is intended for i686 architecture"
> and then subsequent packages don't install because this is a prerequisite.
> I'm taking a guess here, but could this error be related to the fact
> that my linux box (old) is an AMD-K6-2 based box?  If not, does anyone
> have a clue?
> Ed
Mark S VanderVoord
Self-Guided Systems, LLC
