Making Rtems Device Drivers using C?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Tue Jan 4 15:21:07 UTC 2005
Alex wrote:
> Hi,
> I would like to implement a simple device driver to answer printer port requests, but in the rtems documentation I only see referencies to develop rtems drivers using ada... I want to implement it using c, any how-to? any tutorial? any help?
You must be missing something.  All drivers are implemented in C and you
should avoid using Ada (or C++ for that matter) for them due to
potential run-time actions you might not anticipate.  Both Ada and C++
have complex run-times that can use mutexes, block, or allocate
memory at times you might not like.
For an LPT driver, I would think a simple serial device driver
would be a sufficient model to copy.  If it isn't interrupt driven,
then you can probably get away with using the "polled single port"
console driver shell used by psim.
> Thank you
> Alex
> ________________________________________________________________________________
> Finalmente uma Caixa de Correio com todos os Extras: 21 MB + Anti-vírus + Filtro de
> mensagens indesejadas + Attachs 7MB + Bloqueador IOL + Conteúdos IOL + Ícones dinâmicos…
> Crie aqui a sua: http://www.iol.pt/correio/rodape.php?dst=0411151
