Issue with iostream-based hello world example with 4.6.2 release on PSIM BSP
Karel Gardas
kgardas at objectsecurity.com
Mon Jan 10 15:23:10 UTC 2005
Hello,
I've copied hello_world_c example to hello_world_cxx and moved test.c to
test.cc and changed it to:
* Simple test program -- simplified version of sample test hello.
#include <bsp.h>
#include <iostream>
using namespace std;
rtems_task Init(
rtems_task_argument ignored
cout << endl << endl << "*** HELLO WORLD TEST ***" << endl;
cout << "Hello World" << endl;
cout << "*** END OF HELLO WORLD TEST ***" << endl;
exit( 0 );
/* configuration information */
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 1
#define CONFIGURE_INIT
#include <confdefs.h>
/* end of file */
as I've already written I've added make-cxx-exe rule and also modified
example's Makefile so build output now looks:
/mnt/karel/downloads/RTEMS/build/tools/examples-4.6.2/hello_world_cxx$ make
test -d o-optimize || mkdir o-optimize
powerpc-rtems-g++ -B/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/ -specs
bsp_specs -qrtems -g -Wall -g -mcpu=603e -D_OLD_EXCEPTIONS
-Dppc603e -c -o o-optimize/test.o test.cc
-Dppc603e -o o-optimize/hello.exe o-optimize/test.o
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-dpmem.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-event.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-msg.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-mp.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-part.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-signal.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-timer.rel
/mnt/karel/rtems-ppc//powerpc-rtems/psim/lib/no-rtmon.rel
powerpc-rtems-nm -g -n o-optimize/hello.exe > o-optimize/hello.num
powerpc-rtems-size o-optimize/hello.exe
text data bss dec hex filename
332616 65588 23381 421585 66ed1 o-optimize/hello.exe
The problem is that when I try this example in PSIM, I always get:
/mnt/karel/downloads/RTEMS/build/tools/examples-4.6.2/hello_world_cxx$ psim o-optimize/hello.exe
core_find_mapping() - access to unmaped address, attach a default map to handle this - addr=0xfffffff4 nr_bytes=0x4 processor=0x4013b008 cia=0x44754
Is there anything I've done wrong?
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
