netdemo echoServer issue [was: Re: listen/select and then accept pattern not working?]
Karel Gardas
kgardas at objectsecurity.com
Tue Jan 18 07:52:55 UTC 2005
On Tue, 18 Jan 2005, Ian Caddy wrote:
> Karel Gardas wrote:
> > On Tue, 18 Jan 2005, Chris Johns wrote:
> >>Karel Gardas wrote:
> >>>On Mon, 17 Jan 2005, Karel Gardas wrote:
> >>> ++sc->stats.rx_acks;
> >>> rtems_event_send (sc->rx_daemon_tid, INTERRUPT_EVENT);
> >>>+ printf("\nNE: receive packet\n");
> >>Should this be printk rather than printf ?
> > Good note, but does it change anything? i.e. is printf sometimes disabled,
> > sometimes enabled in kernel? I've thought when it prints something, it
> > definitelly works.
> I think what Chris was trying to say was it looks like that code is
> contained in the ISR. printf is not safe to call from an ISR and
> anything could happen. That is the reason for the printk function which
> is safe to call from an ISR.
Aha! I'm starting to understand. Thanks for explanation,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
