PCI lookup issue: 3c905C-TX not found by RTEMS.
gregory.menke at gsfc.nasa.gov
Tue Jan 18 19:09:44 UTC 2005
Karel Gardas writes:
> Hello,
> I'm just trying to make RTEMS works on one of real box here, which
> provides 3c905C-TX NIC. The only issue is that this NIC is not found
> during network initialization, to be more clear it is not found by
> BSP_pciFindDevice function in
> rtems-4-6-branch/c/src/lib/libbsp/i386/shared/pci/pcibios.c file.
> I've checked vendor/device ids and both seems to be right and also defined
> in elnk.c driver. For your reference /proc/bus/pci/devices file from linux
> 2.x running on this machine is attached below. The line containing
> 10b79200 is line representing this card (3com vendor id is 10b7 and card
> device id is 9200)
> Is there any way how to make this card working in RTEMS?
It looks like it should work. I agree the vendor and device id's do
match up, so the driver should handle your board OK. When you attempt
to load the driver, does it say
"etherlink : No Etherlink devices found"
or
"etherlink : device '%s' not found"
If the former, then the pci scanning function is not finding the
board, suggesting a problem with the bsp's PCI library. If the
latter, then you may be using too large a unit number. I somewhat
suspect the former.
Gregm
