PCI lookup issue: 3c905C-TX not found by RTEMS.
Karel Gardas
kgardas at objectsecurity.com
Tue Jan 18 18:59:39 UTC 2005
Hello,
I'm just trying to make RTEMS works on one of real box here, which
provides 3c905C-TX NIC. The only issue is that this NIC is not found
during network initialization, to be more clear it is not found by
BSP_pciFindDevice function in
rtems-4-6-branch/c/src/lib/libbsp/i386/shared/pci/pcibios.c file.
I've checked vendor/device ids and both seems to be right and also defined
in elnk.c driver. For your reference /proc/bus/pci/devices file from linux
2.x running on this machine is attached below. The line containing
10b79200 is line representing this card (3com vendor id is 10b7 and card
device id is 9200)
Is there any way how to make this card working in RTEMS?
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
0000 11060597 0 d0000008 00000000 00000000 00000000 00000000 00000000 00000000
0008 11068598 0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0038 11060586 0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0039 11060571 0 00000000 00000000 00000000 00000000 0000e001 00000000 00000000
003b 11063040 0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0040 10b79200 b 0000e801 d9000000 00000000 00000000 00000000 00000000 00000000
0048 53338811 f d4000000 00000000 00000000 00000000 00000000 00000000 00000000
