PCI lookup issue: 3c905C-TX not found by RTEMS.
gregory.menke at gsfc.nasa.gov
Tue Jan 18 19:47:16 UTC 2005
Karel Gardas writes:
> On Tue, 18 Jan 2005 gregory.menke at gsfc.nasa.gov wrote:
> > If the former, then the pci scanning function is not finding the
> > board, suggesting a problem with the bsp's PCI library. If the
> > latter, then you may be using too large a unit number. I somewhat
> > suspect the former.
> You are right, I see `etherlink : No Etherlink devices found' message on
> the console. I've hacked some debug messages into the pcibios.c file to
> see that it really scans for 10b7/9200 and it really does, unfortunatelly
> does not find it...
> Any hack I should try?
What devices does the pci find device function discover? The thing to
look for is if the device discovery proceeds onto the pci backplane.
Gregm
