PCI lookup issue: 3c905C-TX not found by RTEMS.
Karel Gardas
kgardas at objectsecurity.com
Tue Jan 18 20:20:04 UTC 2005
On Tue, 18 Jan 2005 gregory.menke at gsfc.nasa.gov wrote:
> Karel Gardas writes:
> > Any hack I should try?
> What devices does the pci find device function discover? The thing to
> look for is if the device discovery proceeds onto the pci backplane.
With the patch below, I've got this listing for 10b7/9200 device:
BSP_pciFindDevice: vendor(10B7)/device(9200)
BSP_pciFindDevice: found 0x00497E48 at 0/0/0
BSP_pciFindDevice: found 0x00497E48 at 0/1/0
BSP_pciFindDevice: found 0x00497E48 at 0/2/0
BSP_pciFindDevice: found 0x00497E48 at 0/3/0
BSP_pciFindDevice: found 0x00497E48 at 0/4/0
BSP_pciFindDevice: found 0x00497E48 at 0/5/0
BSP_pciFindDevice: found 0x00497E48 at 0/6/0
BSP_pciFindDevice: found 0x00497E48 at 0/7/0
BSP_pciFindDevice: found 0x00497E48 at 0/8/0
BSP_pciFindDevice: found 0x00497E48 at 0/9/0
BSP_pciFindDevice: found 0x00497E48 at 0/10/0
BSP_pciFindDevice: found 0x00497E48 at 0/11/0
BSP_pciFindDevice: found 0x00497E48 at 0/12/0
BSP_pciFindDevice: found 0x00497E48 at 0/13/0
BSP_pciFindDevice: found 0x00497E48 at 0/14/0
BSP_pciFindDevice: found 0x00497E48 at 0/15/0
not found...
Any idea?
Thanks,
Karel
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
Index: c/src/lib/libbsp/i386/shared/pci/pcibios.c
RCS file: /usr1/CVS/rtems/c/src/lib/libbsp/i386/shared/pci/pcibios.c,v
retrieving revision 1.3.2.2
diff -u -r1.3.2.2 pcibios.c
--- c/src/lib/libbsp/i386/shared/pci/pcibios.c 27 Sep 2004 21:49:18 -0000 1.3.2.2
+++ c/src/lib/libbsp/i386/shared/pci/pcibios.c 18 Jan 2005 20:15:41 -0000
@@ -281,11 +281,13 @@
BSP_pciFindDevice( unsigned short vendorid, unsigned short deviceid,
int instance, int *pbus, int *pdev, int *pfun )
+#define PCI_DEBUG 1
int sig;
unsigned int d;
unsigned short s;
unsigned char bus,dev,fun,hd;
+printk("BSP_pciFindDevice: vendor(%x)/device(%x)\n", vendorid, deviceid);
+getchar();
for (bus=0; bus<BusCountPCI(); bus++)
for (dev=0; dev<PCI_MAX_DEVICES; dev++)
@@ -323,11 +325,13 @@
*pbus=bus;
*pdev=dev;
*pfun=fun;
+printk("SUCCESS\n");
return 0;
+printk("not found...\n");
return -1;
