signal/kill calls
Smith, Gene
gene.smith at siemens.com
Thu Jan 20 23:20:46 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote, On 1/18/2005 11:32 AM:
> Smith, Gene wrote:
>>Smith, Gene wrote, On 1/17/2005 3:17 PM:
>>>The application which I am porting makes a posix style signal() and
>>>kill() call in the code. The application itself does not define these
>>>function. But when I link against rtems, kill() is resolved while
>>>signal() is not. I did not configure my rtems install with
>>>--enable-posix. Anyone know right off where the kill() could be coming
>>>from? Don't see it in libc.a with rtems-objdump.
>>>-gene
>>I reconfigured rtems with --enable-posix added and now the call to
>>signal() resolves OK too. Is it OK to mix posix and standard RTEMS calls
>>in the same application?
> Most definitely. :) It was designed long ago to do this.
In init.c I did not define any CONFIGURE_MAXIMUM_POSIX_... items so it
seem it should use defaults for these (all zero). Yet when I run the
code it fails due to a large (uninitialized?) value for
api_configuration->maximum_queued_signals in posixapi.c because
api_configuration never gets set to &_POSIX_Default_configuration, I think.
So I guess my question is how do you configure a system that will use
99.99% Classic API and just a little posix?
