signal/kill calls
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Jan 18 16:32:51 UTC 2005
Smith, Gene wrote:
> Smith, Gene wrote, On 1/17/2005 3:17 PM:
>> The application which I am porting makes a posix style signal() and
>> kill() call in the code. The application itself does not define these
>> function. But when I link against rtems, kill() is resolved while
>> signal() is not. I did not configure my rtems install with
>> --enable-posix. Anyone know right off where the kill() could be coming
>> from? Don't see it in libc.a with rtems-objdump.
>> -gene
> I reconfigured rtems with --enable-posix added and now the call to
> signal() resolves OK too. Is it OK to mix posix and standard RTEMS calls
> in the same application?
Most definitely. :) It was designed long ago to do this.
> -gene
joel at OARcorp.com On-Line Applications Research
