Help: How RTEMS Interrupt handling Framework Works?
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Sun Jan 23 17:14:51 UTC 2005
Alex wrote:
> Hi,
> I would like to build a ISR to respond to a printer port interrupt, just to be familiar/trainning with interrupt handling in rtems.
> I now that rtems include samples that could help me writing the software but I would like to learn how everything works befiore starting coding.
> So I have been searching for docu,ments documenting the way rtems has to respond to interrupts but I cant find anything.
> Do you know any place where I could get information about the rtems interrupt handling framework?
Which CPU family are you using?  There are two different interrupt
models (unfortunately).
In general terms, you write a C handler for the interrupt, handle
it in the C code, and return.  The difference between the two
models is most obvious in installing the handler.
> Many thanks,
> Alex
> ________________________________________________________________________________
> O IOL aumentou a caixa de correio para 100 MB!
> Saiba mais - http://www.iol.pt/correio/rodape.php?dst=0501181
