PCI lookup issue: 3c905C-TX not found by RTEMS.
gregory.menke at gsfc.nasa.gov
Mon Jan 24 19:55:13 UTC 2005
Karel Gardas writes:
> On Mon, 24 Jan 2005 gregory.menke at gsfc.nasa.gov wrote:
> > > you are probably right, only one thing makes me wonder, my BIOS prints
> > > listing of PCI devices together with assigned IRQ before booting OS.
> > Thats a good sign. What I'd try to do now is use the pci read/write
> > functions you see in pcibios.c to probe the bus, retrieving the device
> > type, interrupt vector and base addresses. For pci bridges, you can
> > look beyond them for other devices on the bus.
> > Your approach to use Linux/bsd to get bus & slot numbers is good, you
> > will be able to confirm what your tests show.
> > To do this, you will need to understand the pci bus a little better;
> > how the address ranges and configuration transactions work. If you
> > look at the pci support in the motorola_shared bsp, you'll see the
> > routine it uses to compute interrupt vectors, which should be of some
> > help as far as how config registers are retrieved and updated. The
> > motorola_shared bootstrap code handles configuring ranges which might
> > also be helpful.
> Perhaps I can at least give it a try. But anyway, short question: is
> 4-6-branch and trunk very similar w.r.t. pc386 pci or should I do this
> hacking directly on trunk? (so far I've hacked rtems-4-6-branch).
As far as I know the pc386 pci support has been stable for some time,
so I think you could do it either way. I imagine it might be better
to work off the cvs head in case you come up with enhancements that
you'd like to commit.
Gregm
