PCI lookup issue: 3c905C-TX not found by RTEMS.
Joel Sherrill <joel@OARcorp.com> joel.sherrill at OARcorp.com
Mon Jan 24 20:19:42 UTC 2005
gregory.menke at gsfc.nasa.gov wrote:
> Karel Gardas writes:
>  > On Mon, 24 Jan 2005 gregory.menke at gsfc.nasa.gov wrote:
>  > >  > you are probably right, only one thing makes me wonder, my BIOS prints
>  > >  > listing of PCI devices together with assigned IRQ before booting OS.
>  > > Thats a good sign.  What I'd try to do now is use the pci read/write
>  > > functions you see in pcibios.c to probe the bus, retrieving the device
>  > > type, interrupt vector and base addresses.  For pci bridges, you can
>  > > look beyond them for other devices on the bus.
>  > > Your approach to use Linux/bsd to get bus & slot numbers is good, you
>  > > will be able to confirm what your tests show.
>  > > To do this, you will need to understand the pci bus a little better;
>  > > how the address ranges and configuration transactions work.  If you
>  > > look at the pci support in the motorola_shared bsp, you'll see the
>  > > routine it uses to compute interrupt vectors, which should be of some
>  > > help as far as how config registers are retrieved and updated.  The
>  > > motorola_shared bootstrap code handles configuring ranges which might
>  > > also be helpful.
>  > Perhaps I can at least give it a try. But anyway, short question: is
>  > 4-6-branch and trunk very similar w.r.t. pc386 pci or should I do this
>  > hacking directly on trunk? (so far I've hacked rtems-4-6-branch).
> As far as I know the pc386 pci support has been stable for some time,
> so I think you could do it either way.  I imagine it might be better
> to work off the cvs head in case you come up with enhancements that
> you'd like to commit.
That's the right answer. :)
> Gregm
