current cvs on powerpc
Keith Robertson kjrobert at alumni.uwaterloo.ca
Mon Jul 11 13:02:01 UTC 2005
Ed Sutter wrote:
>> In RTEMS-CVS/4.7, adding -D_OLD_EXCEPTIONS_PROCESSING to your CFLAGS
>> should do, ... if your BSP is ready to support both kind of exceptions.
> Sorry if I'm just making this confusing, but the gen405 bsp builds that
> way by default.  I didn't touch anything to cause it to build with the
> old-exception-processing model.  Is it possible that the gen405 bsp was
> not updated to use the new-exception-processing model?
It's because you, AFAIK, are using the 4.6.2 branch.  All the changes
that Jennifer and Ralf are referring to are on the head cvs/4.7 branch.
  As you are experiencing, on 4.6.2 the gen405 bsp only supports old
exceptions.
Cheers,
Keith
