current cvs on powerpc
Ed Sutter esutter at lucent.com
Mon Jul 11 13:15:02 UTC 2005
Keith,
Yep, you're right!
Didn't even notice that.  I'm using 4.6.2.
That explains it.
Ed
> Ed Sutter wrote:
>>> In RTEMS-CVS/4.7, adding -D_OLD_EXCEPTIONS_PROCESSING to your CFLAGS
>>> should do, ... if your BSP is ready to support both kind of exceptions.
>> Sorry if I'm just making this confusing, but the gen405 bsp builds that
>> way by default.  I didn't touch anything to cause it to build with the
>> old-exception-processing model.  Is it possible that the gen405 bsp was
>> not updated to use the new-exception-processing model?
> It's because you, AFAIK, are using the 4.6.2 branch.  All the changes
> that Jennifer and Ralf are referring to are on the head cvs/4.7 branch.
>  As you are experiencing, on 4.6.2 the gen405 bsp only supports old
> exceptions.
> Cheers,
> Keith
