New PCI API
Victor V. Vengerov
Victor.Vengerov at oktetlabs.ru
Tue Jul 12 18:41:05 UTC 2005
Till Straumann wrote:
> Traditionally, the BSP simply provided macros
> PCI_MEM_BASE, PCI_IO_BASE, PCI_DRAM_OFFSET
> etc.
> This approach is not good enough when multiple
> 'PCI hoses' are involved.
> Therefore, I'd propose to deprecate those macros
> and require BSPs to provide routines e.g.,
> /* return pci busx memory space as seen from CPU */ void
> *pci_mem_base(int busx);
> /* return pci busx IO space as seen from CPU */
> void *pci_io_base(int busx);
> /* board memory as seen from PCI busx */
> void *pci_ram_base(int busx);
In some hardware, PCI bus is not mapped to memory at all - although
indirect access is possible (e.g. write address to ADDR register, read
from DATA register). (Simplest example is x86 PC :-) : I/O space is not
memory-mapped and accessible through special instructions, but I have
seen much more extravagant PCI bridges). Implementing of PCI API may be
a good point to introduce primitives similar to Linux read{b,w,l},
write{b,w,l}, in{b,w,l}, out{b,w,l}, which accept address on PCI
memory/IO space (in RTEMS case, hose number may be their argument as
well). Ideally, it should be inlined. Drivers should avoid direct device
memory/IO accesses. On traditional systems, these primitives are mapped
to memory access, but arbitrary PCI bridges can be supported.
Victor
Victor Vengerov
OKTET Labs, St.-Petersburg, Russia http://www.oktetlabs.ru
Phone: +78124286709 (office) +78129389372 (mobile) +78124281653 (home)
