[Qemu/PearPC] Question w.r.t. ``starting with 0x1E0'' in motorola_powerpc/README.OTHERBOARDS
Karel Gardas
kgardas at objectsecurity.com
Thu Jul 14 13:50:03 UTC 2005
Short followup: I've found that Qemu when started in PREP more (-M prep
command-line option), seems to emulate `Mesquite cPCI (MCP750)' board, at
least booted linux claims this in /proc/cpuinfo. Also this board seems to
be supported in RTEMS, so my hopes to get it working together still
remain.
Cheers,
Karel
On Thu, 14 Jul 2005, Karel Gardas wrote:
> Hello,
> I'm trying to detect if Qemu PPC or PearPC are good enough to "emulate" some
> PPC board and run RTEMS/PPC. After some investigation I've found that
> motorola_powerpc BSP should be the most closed to some PowerMac/PREP
> hardware, is this right?
> Qemu seems to emulate PPC750 (or that's what I get from it on linux and `cat
> /proc/cpuinfo`), PearPC even seems to be at G4 level (merged altivec
> recently). I've also searched through their sources and found that Qemu
> contains some `raven host bridge' references directly in code -- in PCI bus
> initialization section. So Qemu seems to be more near to the required
> target as described by motorola_powerpc/README.OTHERBOARDS, but now I don't
> know how to detect if Qemu really is ``starting with 0x1E0'' as is written in
> this file. I don't know for which identifier should I look for.
> Any idea?
> Thanks,
> Karel
> Karel Gardas kgardas at objectsecurity.com
> ObjectSecurity Ltd. http://www.objectsecurity.com
