Convert rtems_clock_time_value to UTC (ascii)
Joel Sherrill <joel@OARcorp.com>
joel.sherrill at OARcorp.com
Tue Jul 26 14:16:05 UTC 2005
Ian Caddy wrote:
> Hi Rolf,
> We have this problem as some of our older systems use psos as the OS, so
> we have a conversion utility that converts between RTEMS time and
> standard unix time. The definition we use is:
> #define DELTA_1988_1970_SECS
> (((1988L-1970L)*365L+(1988L-1970L)/4L)*24L*60L*60L)
> I hope this helps.
The POSIX time routines have a similar conversion. It is
called POSIX_TIME_SECONDS_1970_THROUGH_1988. I think
clock_gettime for CLOCK_REALTIME is equivalent to what you are
wanting.
int clock_gettime(
clockid_t clock_id,
struct timespec *tp
> regards,
> Ian Caddy
> Rolf Schroedter wrote:
>> My measurement data has an RTEMS timestamp in seconds,microseconds
>> (rtems_clock_time_value). How can I convert this value later to
>> human-readable UTC.
>> Obviously gmtime() cannot be used, because the RTEMS value has an
>> offset to UNIX-style time_t.
>> Is there a constant #define'ed, which should be added to get a UNIX
>> time_t ?
>> Thanks & regards,
>> ROLF.
>> Rolf Schroedter
>> German Aerospace Center
>> Institute of Planetary Research
>> D-12489 Berlin, Rutherfordstrasse 2
>> Tel/Fax: (+49) (30) 67055-416/384
>> Email: Rolf.Schroedter at dlr.de
joel at OARcorp.com On-Line Applications Research
