is there a ARM ADA package ?
rrk rrk at prairie.lakes.com
Tue Jul 26 18:36:51 UTC 2005
Joel Sherrill <joel at OARcorp.com> wrote:
> Ralf Corsepius wrote:
>> On Mon, 2005-07-25 at 02:13 -0500, rrk wrote:
>>> I'm i correct that there is not an ARM ADA package?
>> No, there isn't any, because GNAT doesn't support the arm.
> I thought that had been resolved.  I know someone who has
> managed to build an arm-linux to build an Ada library for
> his Zaurus.  I am unsure of the gnat version though or any
> tweaks he might have added.
> FWIW still hve not managed to get the right combination to
> get any Ada packages out of gcc 4.0.1. :(
>> Ralf
> --joel
Joel if you could find any info on the Zaurus ADA lib i would greatly
appreciate it(i have one). I'm curious why
there is not an GNAT ARM ADA runtime port? I have looked and looked. Do
you know what the show stoper
is for a GNAT version?  If my understanding is correct it is mostly
ADA(GNARL) and the low level stuff is pretty thin and in GNULL? Your
name showed up many times when searching the GCC list.
I would like to do a project with RTEMS and ADA on TS 7200  (CIRRUS
EP9301).  I have started looking
at what it will take for a board support package.
thank you
rob
http://www.embeddedarm.com/epc/ts7200-spec-h.html
