IRQ latency and context switching on mvme5500 (was Re: RTEMS mvme5500 bsp)
Karel Gardas
kgardas at objectsecurity.com
Thu Jul 28 14:09:33 UTC 2005
Kate,
your experiments looks nice and in favour of RTEMS, but do you have any
numbers comparing latencies between receiving ethernet packet and reading
data from the socket in an application? Or perhaps simple latency
meassurements between two RTEMS and two vxWorks BSPs connected by ethernet
with as simple as possible echo service should be fine too and giving
clear picture.
Thanks,
Karel
On Wed, 27 Jul 2005, Kate Feng wrote:
>> Interested, yes, but I really have no time right now
>> to have a closer look at it -- can you summarize the results?
> Based on the test result, it shows that RTEMS-mvme5500 is
> more deterministic and steadier than vxWorks-mvme5500
> for the highest priority task. For both the idle and loaded system,
> RTEMS-mvme5500 "GUARANTEED" twice or three times
> faster response time in a steadier state. The "worst case" is a
> critical factor in consideration of the real-time system.
>> MVME5500 Interrupt Latency | Context Switching
>> _________________________________________________________
>> max (average) | max (average)
>> Idle System: |
>> RTEMS 5.04 (3.45) | 6.80 (0.96)
>> vxWorks 12.13 (1.58) | 18.68 (0.91)
>> Loaded System:
>> RTEMS 8.17 (3.74) | 24.88 (1.69)
>> vxWorks 22.49 (2.04) | 40.76 (4.1)
>> ** All units are in usec.
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
