IRQ latency and context switching on mvme5500 (was Re: RTEMS mvme5500 bsp)
Kate Feng
feng1 at bnl.gov
Sat Jul 30 19:13:47 UTC 2005
Peter Dufault wrote:
> On Jul 27, 2005, at 10:26 PM, Kate Feng wrote:
> > Based on the test result, it shows that RTEMS-mvme5500 is
> > more deterministic and steadier than vxWorks-mvme5500
> > for the highest priority task. For both the idle and loaded
> > system,
> > RTEMS-mvme5500 "GUARANTEED" twice or three times
> > faster response time in a steadier state. The "worst case" is a
> > critical factor in consideration of the real-time system.
> Can you also include all the identifying information about the
> vxWorks version, and whether you've modified anything from the
> distribution?
Steve changed the cache setup of vxWokrs from
its default (enabled though) to be the same as that of
RTEMS-mvme5500. Now, I get a more comparable result.
This might not imply the conclusion for RTEMS-mvme5500
yet, except I will not be able to enhance it further for a while.
Please note the results of the loaded system vary everyday
depending on the network condition. --Kate
Friday, July 29:
______________________________________________________
MVME5500 Interrupt Latency | Context Switching
___________________________________________________________
max (average) | max (average)
____________________________________________________________
Idle System:
RTEMS 5.04 (3.45) | 6.80 (0.96)
vxWorks 6.10 (1.58) | 9.65 (0.91)
Loaded System:
RTEMS 8.17 (3.74) | 17.48 (1.69)
vxWorks 13.90 (1.68) | 20.80 (1.90)
** All units are in usec.
