RE: Re: CVS checkout
emu at ecubics.com emu at ecubics.com
Fri Jun 10 07:50:59 UTC 2005
>RTEMS uses autoconf and automake tools to generate
>some
>of the files. These are "generated" files and
>therefore
>not usually checked into version control.
>You will need to generate these files if you wish
>to
>build from CVS. To generate these you must have
>autoconf and automake installed... and the
>correct versions of them.
That was hopefully the information I was missing ..
>To generate the files (assuming a valid
>installation of autoconf and automake( run the script
>config/bootstrap in the top director of the source tree.
there is only a bootstrap scripts in the root of rtems ... ?
(rtems/bootstrap), not rtems/config/bootstrap ...)
cheers & thanks
